Follow these steps to update the DPAA2 MC firmware, DPC, and DPL images in QSPI NOR flash.
qixis_reset boots the board from QSPI NOR flash0 and qixis_reset altbank boots the board from QSPI NOR flash1.
sf probe 0:1 means that the alternate bank will be written to. So, if the board boots from QSPI NOR flash0 and sf probe 0:1 is entered at the U-Boot prompt, the commands that follow will program QSPI NOR flash1.
Clone the qoriq-mc-binary repository.
The prebuilt MC firmware image, mc_10.10.0_ls1088a_20180814.itb, is available at /qoriq-mc-binary/ls1088a/.
Note that the name of the MC firmware image may vary depending on the release version used.
Clone the mc-utils repository and compile the DPC and DPL images.
The compiled dpc.0x1D-0x0D.dtb and dpl-eth.0x1D_0x0D.dtb images are available at /mc-utils/config/ls1088a/RDB/.
Note that the name of the DPC and DPL images may vary depending on the release version used.
For example:
For LS1088ARDB, in boot log, you’ll see:
Board: LS1088A-RDB, Board Arch: V1, Board version: C, boot from QSPI:0
For LS1088ARDB-PB, in boot log, you'll see:
Board: LS1088ARDB-PB, Board Arch: V1, Board version: A, boot from QSPI:0
The images can be loaded to the LS1088ARDB/LS1088ARDB-PB from a TFTP server or from a mass storage device (SD, USB, or SATA).
When board boots up, U-Boot prints a list of enabled Ethernet interfaces.
DPMAC1@xgmii, DPMAC2@xgmii, DPMAC3@qsgmii, DPMAC4@qsgmii, DPMAC5@qsgmii, DPMAC6@qsgmii, DPMAC7@qsgmii, DPMAC8@qsgmii, DPMAC9@qsgmii, DPMAC10@qsgmii
=> setenv serverip <ipaddress1>
Set ethact and ethprime as the ethernet interface connected to the TFTP server.
See LS1088ARDB/LS1088RDB-PB Ethernet port mapping for the mapping of Ethernet port names appearing on the chassis front panel with the port names in U-Boot and Linux.
=> setenv ethprime <name of interface connected to TFTP server>
For example:
=> setenv ethprime DPMAC3@qsgmii
=> setenv ethact <name of interface connected to TFTP server>
For example:
=> setenv ethact DPMAC3@qsgmii
Static IP address assignment:
=> setenv ipaddr <ipaddress2>
=> setenv netmask <subnet mask>
Dynamic IP address assignment:
=> dhcp
=> ping $serverip
Using DPMAC3@qsgmii device
host 192.168.1.1 is alive
Program QSPI NOR flash1: sf probe 0:1
Address 0xa00000 is the location of MC firmware in QSPI NOR flash. Refer Flash layout for new boot flow with TF-A for the complete flash memory layout.
Address 0xe00000 is the location of DPC image in QSPI NOR flash. Refer Flash layout for new boot flow with TF-A for the complete flash memory layout.
Address 0xd00000 is the location of DPL image in QSPI NOR flash. Refer Flash layout for new boot flow with TF-A for the complete flash memory layout.
Ensure that SD card, USB flash drive, or SCSI hard disk installed with LSDK Ubuntu distribution is plugged into the board to boot the board to Ubuntu. If U-Boot does not find LSDK on a mass storage device, it will boot TinyDistro from lsdk_linux_arm64_ tiny.itb stored in QSPI NOR flash.
=> mmc rescan=> mmc infoOr
=> usb start => usb info
Or
=> scsi scan
=> scsi info
=> ls mmc <device:partition>
For example:
=> ls mmc 0:2
Or
=> ls usb <device:partition>
For example:
=> ls usb 0:1
Or
=> ls scsi <device:partition>
For example:
=> ls scsi 0:2
=> load mmc 0:2 80000000 <mc firmware>
For example:
=> load mmc 0:2 80000000 mc_10.10.0_ls1088a_20180814.itb
=> print filesize
Or
=> load usb 0:2 80000000 <image name>
=> print filesize
Or
=> load scsi 0:2 80000000 <image name>
=> print filesize
Program MC firmware image to QSPI NOR flash: => sf erase 0xa00000 +$filesize && sf write 0x80000000 0xa00000 $filesize
Flash DPL image:
=> load mmc 0:2 80000000 <dpl image>
For example:
=> load mmc 0:2 80000000 dpl-eth.0x1D_0x0D.dtb
=> print filesize
Or
=> print filesize
Or
=> print filesize
Program DPL image to QSPI NOR flash: => sf erase 0xd00000 +$filesize && sf write 0x80000000 0xd00000 $filesize
Flash DPC image:
=> load mmc 0:2 80000000 <dpc image>
For example:
=> load mmc 0:2 80000000 dpc.0x1D-0x0D.dtb
=> print filesize
Or
=> print filesize
Or
=> print filesize
Program DPC image to QSPI NOR flash: => sf erase 0xe00000 +$filesize && sf write 0x80000000 0xe00000 $filesize
Board: LS1088A-RDB, Board Arch: V1, Board version: C, boot from QSPI:1
Board: LS1088ARDB-PB, Board Arch: V1, Board version: A, boot from QSPI:1
