LS1088ARDB - How to update DPAA2 MC firmware and DPC images in QSPI flash
Follow these steps to update DPAA2 MC firmware and DPC images in QSPI flash, if you are booting LS1088ARDB from the QSPI flash memory.
qixis_reset boots the board from QSPI flash0 (aka bank0) and qixis_reset altbank boots the board from QSPI flash1 (aka bank4).
“sf probe 0:1” means that the alternate bank will be written to. So if you boot from flash0, then enter sf probe 0:1, the commands that follow will program flash1.
Prerequisites
  • Linux machine. It is recommended to install Ubuntu 18.04 on the Linux machine.
Obtaining MC firmware
Download the prebuilt MC firmware image from the git repository: https://github.com/NXP/qoriq-mc-binary/tree/integration/ls1088a
Obtaining DPC image
Clone mc-utils repository and compile the DPC image.
  1. git clone https://source.codeaurora.org/external/qoriq/qoriq-components/mc-utils
  2. cd mc-utils/
  3. git checkout LSDK-18.09
  4. make -C config/
The compiled dpc.0x1D-0x0D.dtb is available at /mc-utils/config/ls1088a/RDB/.
Flash MC firmware image on LS1088ARDB QSPI flash
In U-Boot, boot from flash0, program flash1:
无评分
版本历史
最后更新:
‎09-10-2020 02:41 AM
更新人:
