RedState editor for LPC43S67 support
1,100 次查看
javiervallori
I'm trying to use the SCT module of a LPC43S67. The LPCXpresso has a RedState editor integrated, but in the "target" field on State Machine Settings, it does not appear the LPC43S67 model, even when it has this module. Is there any solution for it? Thank you
标记 (3)
960 次查看
lpcxpresso_supp
You can just select LPC4357 within RedState. The LPC4367 is a LPC4357 with a 2nd Cortex-M0 cpu, and the "S" is not relevant for Redstate/SCT usage.
LPCXpresso Support
961 次查看
lpcxpresso_supp
LPCXpresso Support
