Content originally posted in LPCWare by canisrays on Mon Dec 17 21:44:02 MST 2012
Is there a means to specify LPC1343 pins be pulled low and made outputs vs inputs and floating at startup?
We have a circuit that for safety reasons at boot must keep some pins pulled low. The LPC1343 by default seems to make the pins inputs and floating at boot.
Setting the pins to outputs and low as soon as user code execution starts is not an acceptable solution because this does not resolve the issue of the pins being inputs and floating when the uC enters one of the bootloader modes (SPI, jtag, usb msd).
