Content originally posted in LPCWare by remcopoelstra on Fri May 30 07:10:32 MST 2014 Hi,
Today I had installed version 7.2.0. I've been using today and it worked fine. When I wanted to open it again, it gives a splash screen and then a dialog with the following error:
---------------------- An error has occurred. See the log file <removed>/workspace/.metadata/.log. ---------------
I've added the log. At one of the last lines it references /DSPProgrammerTest/DSPProgrammerTest Debug.launch, which does exists inside the workspace.
How can I get LPCXpresso working again?
Kind regards,
Remco Poelstra
Original Attachment has been moved to: log_3.txt.zip
Content originally posted in LPCWare by lpcxpresso-support on Fri May 30 07:50:13 MST 2014 I'd suggest that you create a new empty workspace and import your projects from your old workspace.
