LPCXpresso lpc1769 rev-c board
Search instead for
Content originally posted in LPCWare by barianand on Sat Oct 24 04:04:36 MST 2015
I am beginner in lpc1227.
I am trying to program for lpc1227 with lpcxpresso v7.9.2_493 & through the LPCXpresso lpc1769 rev-c board.
I connect my lpcxpresso board with my lpc1227 board with the help of JTAG.
Now my problem is when i am connecting that LPCXpresso board to my computer it is not showing connected in my device manager.
& if still i am trying to debug my code then it shows mi such error.
LPCXpresso:Error=>
cannot run program "wmic": createProcess error=2, The system cannot find the file specified.
Connect to emulator=>
This could be because it is disconnected , not powred , or already in use.
So now please help mi how to overcome this this problem.
I have the same problem and the link above doesn't work. Please, can you explain how fix this error? Thanks!
Just in case anybody is interested - I found it here: Windows PATH issues | www.LPCware.com
in my case the %SystemRoot%\system32\wbem was missing in my path variable.
Content originally posted in LPCWare by TheFallGuy on Sat Oct 24 09:37:12 MST 2015
Read this FAQ
https://www.lpcware.com/content/faq/lpcxpresso/windows-path-issues
