Interfacing of TSOP SENSOR with LPC1769 EA baseboard
743 次查看
lpcware
Content originally posted in LPCWare by kuldip rajput on Sun Apr 05 22:03:58 MST 2015
Hello Sir,
       I want to interface  TSOP SENSOR FOR OBJECT DETECTION on the LPC1769 EA baseboard with the help of expansion connector. May I know the procedure for interfacing an external peripheral on EA baseboard through the GPIO. I am unable to get the EA baseboard schematic for finding the pin configuration on the expansion connector.
May I know how to connect the pins of expansion connector with the LPC1769 controller stamp.
would any body please help me regarding this issue.
1 回复
702 次查看
lpcware
Content originally posted in LPCWare by cfb on Sun Apr 05 23:58:18 MST 2015
After you register your board with Embedded Artists you can login and download the schematic from here:
http://www.embeddedartists.com/products/lpcxpresso/xpr_base.php
