Content originally posted in LPCWare by SSzretter on Tue Sep 06 16:07:03 MST 2011 I am getting started with the LPC 1769 unit and want to set up some simple ethernet communications. I found the EasyWeb example project, but I am trying to verify how exactly the ethernet port is wired up.
Is there anything required beyond simply wiring the pins on the LPC unit to the corresponding pins of a female RJ45 jack, OR are there additional components required (coils?) as suggested on this page: http://vebug.com/lpcxpresso ?
