In the build console view, there are warnings and errors. There is a very dim highlight for errors, making it impossible to see which are errors. Is there a way to change the highlight color or intensity? There is no option in the /General/Appearance/Colors and Fonts location for this, nor is there a system color that matches these highlights. How can I make compile errors visible by changing the highlight color?
To change the colours used in the build console, go to : Preferences -> C/C++ -> Build -> Console
Note : You might also find the Problems view (which is located in parallel with the Console view) useful for quickly moving between errors in your build.
