In the build console view, there are warnings and errors. There is a very dim highlight for errors, making it impossible to see which are errors. Is there a way to change the highlight color or intensity? There is no option in the /General/Appearance/Colors and Fonts location for this, nor is there a system color that matches these highlights. How can I make compile errors visible by changing the highlight color?
Solved! Go to Solution.
To change the colours used in the build console, go to : Preferences -> C/C++ -> Build -> Console
Note : You might also find the Problems view (which is located in parallel with the Console view) useful for quickly moving between errors in your build.
LPCXpresso Support
LPCXpresso Support
Oh, that's great! Thank you very much! I spent quite a bit of time
looking for the right place where this could be set and missed this.
Robert Morrison
On Mon, Nov 7, 2016 at 1:44 AM, lpcxpresso_support <admin@community.nxp.com>
