How can I change very dim error highlight? I can't see it
robertmorrison
In the build console view, there are warnings and errors.  There is a very dim highlight for errors, making it impossible to see which are errors.  Is there a way to change the highlight color or intensity?  There is no option in the /General/Appearance/Colors and Fonts location for this, nor is there a system color that matches these highlights.  How can I make compile errors visible by changing the highlight color?
Labels (2)
lpcxpresso_supp
To change the colours used in the build console, go to : Preferences -> C/C++ -> Build -> Console
Note : You might also find the Problems view (which is located in parallel with the Console view) useful for quickly moving between errors in your build.
LPCXpresso Support
lpcxpresso_supp
LPCXpresso Support
robertmorrison
Oh, that's great! Thank you very much! I spent quite a bit of time
looking for the right place where this could be set and missed this.
Robert Morrison
On Mon, Nov 7, 2016 at 1:44 AM, lpcxpresso_support <admin@community.nxp.com>
