The debugger hardware I am using is the Jlink Base and the controller is the LPC11C24
I have the same question and I see that no one has offered a solution. Segger does have a link on their page (Eclipse | SEGGER - The Embedded Experts ) which says to install the "GNU ARM Eclipse Plugin". They offer several methods and each of them fails saying that "Cannot complete the install because one or more required items cannot be found." This happens whether you point to the plugin on the web, or download it as a local ZIP and install from that.
Does this require the PRO version? If I pay NXP for the upgrade, will the Segger software be installable?
Thanks!
Ever tried google? Searching for LPCXpresso J-Link gives this link first
