Download a release build to my target
lpcware
Content originally posted in LPCWare by tvink on Fri Apr 22 14:01:41 MST 2016
I built my code for release and am using the quick panel "Debug....[Release]" link to run it.
Is the code downloaded to my target this way the release version?
Should I be able to use the commands in the "Run" menu to download to my target?  I have not been able to configure something that actually downloads.
Tony
lpcware
bump
lpcware
Content originally posted in LPCWare by tvink on Wed Apr 27 07:22:17 MST 2016
Thanks, useful to know...
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Mon Apr 25 07:40:39 MST 2016
If you look in the debug log, you can see what the tools are doing are you launch a debug connection.
https://www.lpcware.com/content/faq/lpcxpresso/debug-log
LPCXpresso Support
lpcware
Content originally posted in LPCWare by tvink on Mon Apr 25 07:02:07 MST 2016
Thanks...
lpcware
Content originally posted in LPCWare by vtw.433e on Sat Apr 23 01:53:30 MST 2016
Yes
