Does the Redlib(none) library varient provide stub for the malloc()?
787 次查看
chaitanyapravee
Hello everyone,
I am trying to understand the library variants provided by the lpcxpressov8.2.2. According to What are none, nohost and semihost libraries? the none variant will not provide stubs for all file-based I/O and some string and memory handling functions.
What all are the memory and string function it will not provide stubs?
Does it provide stubs for malloc() and free()?
544 次查看
lpcxpresso_supp
Yes, malloc() should work linking against Redlib (none). Generally, I would recommend that you link against Redlib (none) and then switch to Redlib (nohost) only if functions you are using trigger link errors, of the form described in ...
https://community.nxp.com/message/630711
LPCXpresso Support
