Convert a 'C' code into an assembly instructions in LPCXpresso IDE
3,567 次查看
himanshudoshi
Hello to all,
I would like to convert my C code into the corresponding assembly code while compiling and wanted a copy of that to be saved into the project directly. So, what setting can be applied to the project property in the IDE?
For example, a C code of Fibonacci series in an assembly language?
Can anybody help me out with that?
Thanking you in advance,
Himanshu
标记 (1)
2,864 次查看
lpcxpresso_supp
See the FAQ : https://community.nxp.com/message/630600
LPCXpresso Support
2,865 次查看
driesmoors
LPCXpresso is using gcc for compilation. You can try adding the -S option to see the output of the compilation process (i.e. the assembler code). See Using the GNU Compiler Collection (GCC): Overall Options  (Press Page Down a few times to find the -S option.)
Dries.
