Content originally posted in LPCWare by GBTech on Wed May 21 13:06:17 MST 2014
I downloaded the most recent LPCXpresso and installed it into the default directories with sudo. When I try to run it from the menu bar, the flash screen comes up for about 12 seconds and then goes away with no further information. I have uninstalled and reinstalled LPCXpresso at least three times.
I have carefully read section 2.2.2 (How to install on Linux) of the newest user manual and that mostly applies to 64 bit systems. Mine is a 32 bit computer. I think I am using the Kubuntu equivalent version of Ubuntu 12.04.
(Why don't I try it on Ubuntu, you may ask. I did. See the forum entry: “While trying to solve the “Connection Refused” error I crashed my Ubuntu system.”)
Is there a way to run LPCXpresso on Kubuntu, or is Kubuntu too different from Ubuntu?
Thank you.
