I flashed my LPCXpresso824-Max board incorrectly and now the debugger does not work. Is it possible to roll back things back to factory settings?
I've already tried everything listed in the question "Regaining debug access to target MCU" from March 31, 2016, and no help. (I think I had violated this suggestion in the note: The image contains code that sets the MCU clocks up "incorrectly")
I'm attaching an image showing the IDE's errors.
Thanks!
We'll post a response back in your other thread .... https://community.nxp.com/thread/461997 (which we also will move to the MCUXpresso IDE forum (as you say you mention using that IDE rather than the older LPCXpresso IDE).
MCUXpresso IDE Support
