I have both LPC55s1x-EVK and LPC55s2x-EVK. They were working fine. I was able to debug with MCUXpresso IDE (v11.5.0). And suddenly I can't. MCUXpressor gave me an error saying that no device was found while my board was connected to the PC like when it was working fine.
I checked the device manager and it shows that LPC-LINK2 is still connected can be found by the MCUXpresso as shown below.
I tried to reset with ISP button and it didn't work. No hardware changes were done.
Thanks.
Solved! Go to Solution.
Hi @giantmango
Please power cycle the boards and when you get the MCU into ISP mode perform a mass erase using the MCUXpresso or try to do that mass erase using the Flash Magic Tool , this communicates with ROM bootloader.
If you are encounter more problems, or do not know how to do the recommended steps let me know.
Diego.
Hi @giantmango
Diego.
