what is emWIN_512_Libraries_112311_Keil.zip file?
lpcware
Content originally posted in LPCWare by zaalzaalak on Thu Dec 01 11:35:05 MST 2011
I found this file on lpcware site but I can not find any comment on it.
What is this file? please explain it in more detail.
lpcware
Content originally posted in LPCWare by ktownsend on Mon Dec 05 12:15:57 MST 2011
Only framebuffer (memory) based devices are supported in the library since it is intended to be used with MCUs with an LCD controller where you store the framebuffer in memory (either internally for smaller displays or using SDRAM or SRAM on larger models).  Segger's website has a lot more information on the library.
lpcware
Content originally posted in LPCWare by zaalzaalak on Sat Dec 03 13:38:37 MST 2011
Can we use it with any color TFT lcd controller like as ILI9325? if yes how to find driver for controller? please explain more on its using in a project.
lpcware
Content originally posted in LPCWare by zaalzaalak on Sat Dec 03 13:38:22 MST 2011
same
lpcware
Content originally posted in LPCWare by usb10185 on Thu Dec 01 14:27:51 MST 2011
The file is the eWin v5.12 Libraries for (ARM7, ARM9, M3 and M4) compiled with Keil MDK
