- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
I'm new on using LWIP and I'm taking my first steps into it. I'm using a self-designed board based on LPC1788 microcontroller and I've been able to run both the lwip_tcpecho and the lwip_web projects successfully so far (I'm using raw API without RTOS).
Now, I would like to send and receive data via a TCP connection but I'm a bit lost where and how to start doing this. I was thinking, as my first step, that I might modify the lwip_tcpecho example in order to show via the DEBUGOUT UART the received data and to send via the TCP connection the data read from DEBUGIN. (Something like a simple RS-232 to TCP converter).
Has anyone done something like this? If so, could you share some piece of code that helps me?
Am I taking the right path? I'm not using RTOS since in the future I have to add this to my existing code which doesn't run RTOS.
what function should I call to get the data received into my app buffer and what function should I call to send data from my app buffer?
Regards!
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Gonzalo Sanchez,
Thanks for your reply.
To provide the fastest possible support, I'd like to you refer to the LwIP Application Developers Manual.
TIC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Gonzalo Sanchez,
Whether you use the Lwip demos which comes from the LPCOpen library as the template demo, if yes, it's a good start.
Meanwhile, implement a simple RS-232 to TCP converter is the right choice to move further, so please give a try, and ask the question if you encounter some troubles
TIC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Jeremy, thank you for let me know that I'm on the right path.
What I do not totally understand is how my application can interact with LWIP to receive and send information. I mean, what function should I call to get the data received into my app buffer and what function should I call to send data from my app buffer?
I've updated my post with this question too.
Gonzalo.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Gonzalo Sanchez,
TIC
