nxp官网例程编译出错
nxp官网例程编译出错
469 次查看
tongjunju
1.The following is a routine on the NXP website :
(IAR EWARM 6.70.1Keil MDK-ARM v4.73a)
2.When I compile "ucos_iii_blinky" project called A with keil 5, The following error occurred.
(The path of this project : C:\Users\Administrator\Desktop\applications\lpc17xx_40xx\keil_uvision_projects\nxp_lpcxpresso_1769\ucos_iii\
ucos_iii_blinky)
How can I solve this problem?
355 次查看
kerryzhou
Hi tongjun,
    You missed the library.
    Please open nxp_lpcxpresso_1769_ucos_iii_examples in folder:lpcopen_2_10_keil_iar_nxp_lpcxpresso_1769\applications\lpc17xx_40xx\keil_uvision_projects\nxp_lpcxpresso_1769
   Then build the two lib project at first, then build the application project.
   If you still have question, please let me know!
Kerry
