lpcxpress iDE pemicro multilink universal tools config
jongsubkim
lpcexpress IDE not config(SWD) Pemicro multilink universal problem !
Howto configulation help me!
ZhangJennie
Hi jongsub kim
LPCXpresso IDE can't support UMultilink.
But with below plugin , LPCXpresso will be compatible with P&E products, like the Multilink Universal.
GDB Server plug-in for Eclipse-based ARM IDEs | GDB Server plug-in for Eclipse-based ARM IDEs | PEmi...
Below information was provided by P&E support Mika:
To install the plugin in LPCXpresso, please navigate to Help -> Install New Software, and in the "Work with:" field, enter this URL:
http://www.pemicro.com/eclipse/updates
You can read P&E full instructions on installing the Eclipse Plugin here:
http://www.pemicro.com/blog/index.cfm?post_id=124
Jun Zhang
converse
Senior Contributor V
I am pretty certain that LPCXresso does not support PEMicro - you need to use MCUXpresso.
ZhangJennie
Hi jongsub kim
What's your chip part number? I will check it.
Have a nice day,
Jun Zhang
jongsubkim
Im LPC11e36 used
OntechOne Co.,LTD.
JongSub KIM
(SambooMTS 202), 22,86Beon-Ahngil ,Sanbon-ro,
Gunpo-si, Gyeonggi-do,KOREA(zip:15847)
경기도 군포시 산본로86번안길 22(당정동) 2층202호(우:15847)
TEL     : 02-857-5020
FAX     : 02-857-5037
mobile  : 010-6381-3981
Home   : www.apptools.kr
e-mail : ssjsk12@outlook.com
e-mail : ssjsk12@gmail.com
보낸 사람: ZhangJennie
보낸 날짜: 2019년 4월 25일 목요일 오후 4:25
받는 사람: jongsub kim
제목: Re: - Re: lpcxpress iDE pemicro multilinkuniversal tools config NXP Community
Re: lpcxpress iDE pemicro multilink universal tools config
reply from ZhangJennie in LPC Microcontrollers - View the full discussion
Hi jongsub kim
Have a nice day,
Jun Zhang
Reply to this message by replying to this email, or go to the message on NXP Community Start a new discussion in LPC Microcontrollers by email or at NXP Community Following Re: lpcxpress iDE pemicro multilink universal tools config in these streams: Inbox This email was sent by NXP Community because you are a registered user.
You may unsubscribe instantly from NXP Community, or adjust email frequency in your email preferences
