lpc802 gpio中断问题
lpc802 gpio中断问题
2,637 次查看
vector123456
各位,请教一下,LPC802  在SDK中有没有 gpio的中断示例代码?
如果没有的话,能否给一个提示?
2,543 次查看
Hello vector guo,
Yes, as Jeff Chang said, you can find "gpio_led_output" demo under SDK package,
This example shows how to use GPIO with interrupts and make the led shine.
TIC
4 回复数
2,544 次查看
Hello vector guo,
TIC
2,543 次查看
vector123456
谢谢!
2,543 次查看
JeffChang
Yes.  You can find it on the SDK.
SDK--> driver sample code.
2,543 次查看
vector123456
谢谢!
