chip is damaged?
chip is damaged?
851 次查看
skysky
lpc4353 flash download failed
Is it damaged?
728 次查看
jeremyzhou
Hi sky sky,
Thank you for your interest in NXP Semiconductor products and
for the opportunity to serve you.
Whether the MCU can enter the ISP mode successfully, if yes, you can use the Flash Magic to erase the flash completely to unlock the MCU.
Hope it helps.
TIC
