Content originally posted in LPCWare by dsidlauskas on Fri Feb 27 11:55:03 MST 2015
It's not easy to get at as it's not brought out to a header pin. I was able to pick it up on the SDRAM chip, but this takes a sharp eye and a steady hand with the soldering iron. Check the board schematic.
On the other hand, It's not clear to me that this really needs to be pulled up. I have used other NGX boards without a pull-up with no problem. I've read conflicting advice on this topic.
Good Luck
