Where to find LPCDfu.dll for x64 or some info about the library
2,088 次查看
diegura
My program has a dependency to the LPCDfu.dll
actually it is using version:  '0.5.6.15336'
I don't have informations about this dll or also if some other new library is replacing the functionality. I would prefer to keep this one to don't mess around with legacy code which is already working in production and not causing any troubles.
Any info would be aprecciate.
I can read the whole LPCDfuNS namespace and I could also recreate a project from the assembly with reflection and recompile but I wanted to do it right
thanks again
Diego
2,059 次查看
ZhangJennie
Hi diegura
Please provide us more information.
1. your chip part number?
2. what NXP SW package do you work with? please provide me download link. thus I can find if there is newer version for you.
Jun Zhang
4 回复数
1,837 次查看
diegura
Hi Jun Zhang, Very sorry my late response but something went wrong with my login and I couldn't follow the link to answer you.
Anyways, thanks a lot. Sorry my mistake, the proyect is inside our Company, it uses code snippets from your company but I found the project so finally with the sources  will just re compile in x64.
Thanks for the links, I will also try a newer driver.
Thanks a lot for your concern
Diego
2,042 次查看
diegura
Hi Jun Zhang,
Thanks a lot for for your fast answer. I'll try here to provide what I know about the DFU loader because it was introduced by other developer in 2016 in our hardware, but I didn't find so much docu about it.
1. Chip is LPC1857
2. I compiling with C# using .NET Framework 4.7.2 (I can upgrade if needed) and I can see a dependency manualy added which is called:
LPCDfu.dll
if you think a .dll will help you to find out more just let me know and I can upload it here
Xie Xie and Have a nice Day
Diego
2,027 次查看
ZhangJennie
I checked our database, I didn't find we ever  released LPCDfu.dll file.
Please make sure is file is from NXP.
If you need LPC18xx USB demo code, Please download the latest lpcopen demo code here
https://www.nxp.com/design/software/development-software/mcuxpresso-software-and-tools-/lpcopen-libr...
USB demos are included. The driver supports both win7/10.
Jun Zhang
2,060 次查看
ZhangJennie
Hi diegura
Jun Zhang
