Where can i find what goes in the config.yaml file used by nxpkeygen?
1,591件の閲覧回数
andrewfisher
Hello I am trying to use nxpkeygen to generate a DC for debug authentication as described in LPC55sxx Debug Authentication pg10.
However this command insists on a config.yaml (or config.yml - the document is inconsistent), however, there is no description of what goes in this file other than "debug access restrictions and so on".
Please can you point me to where I can find the documentation of what needs to be in the file. Or at least maybe and example file.
Thanks.
1,586件の閲覧回数
ZhangJennie
Hi andrewfisher
This file config.yaml  is included in AN13037SW
Please download it here:
https://www.nxp.com/docs/en/application-note-software/AN13037SW.zip
Best Regards
Jun Zhang
3 返答(返信)
1,587件の閲覧回数
ZhangJennie
Hi andrewfisher
Best Regards
Jun Zhang
1,582件の閲覧回数
andrewfisher
Thank you so much for such a quick reply.
I'm not one for using forums much but am starting to really like the NXP one as I actually get real answers.
Thank you
1,575件の閲覧回数
ZhangJennie
You are welcome.
