Where can i find what goes in the config.yaml file used by nxpkeygen?
1,514 次查看
andrewfisher
Hello I am trying to use nxpkeygen to generate a DC for debug authentication as described in LPC55sxx Debug Authentication pg10.
However this command insists on a config.yaml (or config.yml - the document is inconsistent), however, there is no description of what goes in this file other than "debug access restrictions and so on".
Please can you point me to where I can find the documentation of what needs to be in the file. Or at least maybe and example file.
Thanks.
1,509 次查看
ZhangJennie
Hi andrewfisher
This file config.yaml  is included in AN13037SW
Please download it here:
https://www.nxp.com/docs/en/application-note-software/AN13037SW.zip
Best Regards
Jun Zhang
1,510 次查看
ZhangJennie
Hi andrewfisher
Best Regards
Jun Zhang
1,505 次查看
andrewfisher
Thank you so much for such a quick reply.
I'm not one for using forums much but am starting to really like the NXP one as I actually get real answers.
Thank you
1,498 次查看
ZhangJennie
You are welcome.
