Where can I find the head file --fsl_flash.h
1,922 次查看
zhangeh10594
fsl_flash.h      Recently I'm writing code for flah IAP code, that is remote program upgrade,and I found in SDK's examples which is flashiap1 test. I noticed there rementioned fsl_falsh.h. but I didn't find the fsl_flash.h.  So where can I find this head file .Please give me a link towards this.And if there some  other IAP code that I can learn from?
My MCU is LPC55S69.
标签 (1)
4 回复数
1,834 次查看
Hello  小白 张,
The flash IAP code about LPC55s69 please refer to the files of "fsl_iap.c" and "fsl_iap.h".
The file of " fsl_flash.h" is not for this chip, it is for kinetis products.
TIC
1,834 次查看
mark2
I blogged about IAP on LPC55S69 last week - see here: Investigating ARM Cortex® M33 core with TrustZone® – In-Application Programming Tutorial | MCU on Ec...
I did not find any reference to fsl_flash.h or fsl_falsh.h in version 2.6.3 of the SDK. I don't think that you need this file. Were is the reference in your flashiap1 example?
Mark
1,834 次查看
zhangeh10594
BTW, I can't open the video in your blog. And whethercan you  give me the code of LED blinky programs of IAP examples.Because I'm not very sure how to use the IAP program examples. Thank you very much.
1,834 次查看
zhangeh10594
Thank you very much , your blog is very helpful.Thanks again!
