I used LPC54628, designed web server. I found SDK lwip_httpsrv. I can modify HTML file, but which tools can convert HTML to C language arrays? Many thanks!
解決済! 解決策の投稿を見る。
This is AE reply:
in SDK's "\middleware\lwip\src\apps\http\makefsdata" folder, there is makefsdata source code for convert HTML to C, customer need use Visual Studio to compile it to exe or other compiler tools for PC OS.
Visual Studio project under folder "middleware\lwip\contrib\ports\win32\msvc"
Hope it can help you
XiangJun Rong
For HTTP server, it uses CGI protocol.
Pls search the CGI protocol for the http server.
XiangJun Rong
it appears that the https://realtimelogic.com is used.
Anyway I have asked the AE team, I will update after I get reply.
XiangJun Rong
This is AE reply:
XiangJun Rong
Thank you very much!
