What is the recommended microcontroller series that replaces the LPC213x series?
bpdohertyman
I am looking for a microcontroller that I could port an existing LPC2138 design to, preferably having USB support.
vicentegomez
There is no direct replacement for the LPC2xxx family  but depending on your application you can check the followings options
LPC54xxx family
LPC55xxx family
or if you only need the USB you also can check the
LPC51U68
