The device we have developing will be deployed in field application. So, if
there is any removal or re insertion of USB cable, it might have affect on
this bit. The entire USB communication will be disturbed if due to some
event the VC bit gets reset which inturn will turn off the VBUS supply.
So, is this a recommended solution (because it is not a hobby project ,but
will be a product)? or implementing the VBUS_SIGNAL through the hardware
will be a better and durable solution????
please respond as soon as possible.
thanks,
Sooraj.
Siemens
-Sooraj.
