Unused USB pins
Unused USB pins
1,111 次查看
jpowning
Regarding the USBn_3V3 pins, the datasheet says "Tie to VBAT_DCDC or connect to ground . If not using USB and using 1.8 V supply, USBn_3V3 can be connected to 1.8 V." This is confusing. If you are not using USBn, and it says it can be connected to ground, then why not connect it to ground (to minimize supply current)?
1,101 次查看
ZhangJennie
Hi jpowning
What's the part number?
Jun Zhang
1,093 次查看
jpowning
Hi - the part I am using is LPC55S16JBD100. Thanks for your interest.
1,076 次查看
ZhangJennie
Please use the DS recommended design for unused USB pins. This is related with on chip HW design.
you should consider USB low power mode or disable USB domain to lower the power consumption.
Jun Zhang
