Uart Buad Rate Error of LPC55xx
1,435 次查看
rahul_4
UART Baud Rate error and is not defined in the datasheet. Can you please tell me, what is the Uart buad rate error in LPC55xx series?
Rahul
1,408 次查看
Miguel04
Hi @rahul_4
I'm not able to understand completely what are you refering to.
Is it possible for you to provide a more detailed explanation to look for the correct answer please?
Best Regards, Miguel.
1,392 次查看
rahul_4
Hi Miguel,
If the selected UART Baud Rate is 9600, what is the error percentage in the output? Is it within +-1% or +-3%?
For +-1% it will be -> 9504 to 9696 baud rate
Rahul
1,372 次查看
Miguel04
Hi @rahul_4
There isn't a specification about a deviation on the baudrates generated for the uart. The baudrate deviation could be affected by the precision of the clock.
