USB SDK STRUCT_UNPACKED
2,242 次查看
rex_lam
In usb_misc.h, STRUCT_UNPACKED is defined as follows.
#if defined(__ICCARM__)
#ifndef STRUCT_PACKED
#define STRUCT_PACKED __packed
#endif
#ifndef STRUCT_UNPACKED
#define STRUCT_UNPACKED
#endif
#elif defined(__GNUC__)
#endif
#define STRUCT_UNPACKED __attribute__((__packed__))
#endif
#elif defined(__CC_ARM) || (defined(__ARMCC_VERSION))
#define STRUCT_PACKED _Pragma("pack(1U)")
#endif
#define STRUCT_UNPACKED _Pragma("pack()")
#endif
#endif
Is the definition for __GNUC__ wrong? I expected STRUCT_PACKED to be __attribute__((__packed__)) instead of the other way around, i.e.
#define STRUCT_PACKED __attribute__((__packed__))
#endif
#endif
标签 (2)
标记 (3)
6 回复数
2,174 次查看
soledad
We don't have any issue regarding this, however, we will check it internally. Thank you for your feedback,
Soledad
1,926 次查看
HSL_AB
Years pass - and SDK_2_11_1_MIMXRT1052xxxxB pack still contains this old described error in the "usb_misc.h" file. What is your reason?
1,906 次查看
frank_m
Senior Contributor III
Perhaps this only potentially becomes a problem when using different platforms or different toolchains in a  project/system.
And affected users don't lament loud enough ...
1,903 次查看
HSL_AB
While STRUCT_UNPACKED is not used in SDK there is no problem: let assume that nobody will use this #define deliberately
1,900 次查看
frank_m
That depends.
In my experience, "packed" structs are often used as overlays for serial data transfer (ethernet, Modbus, USB, CAN) and in data file interpretation.
In most cases, metadata are embedded in the byte stream, and interpreted via the "packed" overlay structure.
However, such projects usually included a manual check that the linker-generated struct offsets really matched the intended sizes/offsets.
1,898 次查看
HSL_AB
Obviously, "packed" does be widely used, but I assume that little people know about the existence of this particular #define. I hadn't known before.
