UART_IRQ_util.c file
2,008 次查看
Alex_2221
Hello everyone, I want to use UART interrupt and I found out that there is a file called uart_irq_util.c for keil and I can use it for working with uart interrupt. Where can I find this file? I know that I can write my own file, but I wanna use this file for simplicity.
Thanks in advance,
Alex
1,990 次查看
xiangjun_rong
It appears that there is NOT such file uart_irq_util.c for the uart example in SDK based on  Keil. For the uart module api function, pls refer to the uart_17xx_40xx.c, for the interrupt vector, pls refer to keil_startup_lpc175x_6x.s
How do you know that there is a file called uart_irq_util.c?
XiangJun Rong
1,991 次查看
xiangjun_rong
XiangJun Rong
1,980 次查看
Alex_2221
Thank you so much I'll check that out. Actually, I saw that in a tutorial video, but that person didn't said from where he got that file.
1,995 次查看
Alex_2221
My chip is LPC1768
标记 (1)
