The minimum power consumption of LPC1102
1,956件の閲覧回数
857753886
We urgently need to know the minimum power consumption of LPC1102 when configured with CPU working mode.In other words, I want to know the minimum CPU configurable frequency.Here are some materials I found for your reference.(the first document is the source code of LPC1102, the second document says the power consumption is 130ua/MHZ, so I want to know the lowest frequency it can reach, the third document page 11, 7.14 clock and power control.)Thanks for your help.
タグ(1)
1,767件の閲覧回数
xiangjun_rong
Hi, JinChi,
Regarding the core clock frequency, it can reach up to 50MHz, but we do not specify the minimum clock frequency, in other words, I think the clock frequency can be any value as you want. We gave the spec of 130uA/MHz, generally, the power consumption is proportional to the clock frequency in a limited range of clock frequency, but for extreme clock frequency for example 1KHz, there is a minimum value, but we do not specify in data sheet.
Hope it can help you
Xiangjun Rong
