Running the NXP-NCI project. Error: cannot connect to NXPNCI device
1,704 次查看
Gas
Hi All,
I worked fine in a project based on NXP-NCI_LPC55xx_example, but now in the debug session I see always :"Running the NXP-NCI project. Error: cannot connect to NXPNCI device".
I plugged OM5578/pn7150 Board.
Any help?
1,672 次查看
Gas
Hi  victojimenez,
due to backup and copy, the Ven and Irq pins was missed. I don't know the reasons. In every case I'd solved.
1,663 次查看
victorjimenez
Thanks for sharing your findings! I'm glad to hear that you were able to solve the problem.
Victor
1,679 次查看
victorjimenez
I apologize for the late response. Did you modify the example? If so, which changes did you make? I made some tests on my end with the example as it is and I didn't face any problems.
Victor
