Hi, Ian,
I suppose that you use LPC175x, if it is the case, you can reset only the CAN module with the bit CCAN_RST bit, in other words, you can set the bit, then clear the bit, the CAN module will be reset, then you can reinitialize the CAN module.
XiangJun Rong
