Reading I/O into emWin
915 次查看
lpcware
Content originally posted in LPCWare by jeffbelz on Thu May 02 07:00:38 MST 2013
I'm using the emWin interface, but a little confused about how to read an input and make something happen on the screen.  Example:  I have a list box and I want the select an option of that listbox using a couple I/O on the micro.  Up, Down and select would be the input pins.  When I press "Up" I want it to move the selction up.
Really my biggest probelm is where do I put the code to read the input.
848 次查看
lpcware
Content originally posted in LPCWare by EReyes on Tue May 07 17:45:34 MST 2013
-- double post deleted
848 次查看
lpcware
Content originally posted in LPCWare by EReyes on Tue May 07 17:44:48 MST 2013
Take a look at chapter 24 of the emWin manual. Basically you just need to call GUI_StoreKeyMsg from your GPIO interrupt handler.
