Power on boot up time and security features of LPC55S36JHI48
288 次查看
limingzhou
Hi experts,
Q1:
Can you share any documents describing the security features of LPC55S36JHI48 ?
Does LPC55S36JHI48 have PSA level 3 certificate ? any document stating it ?
Q2:
What is the duration of boot rom execution after power on ?
What is the amount of time from power on reset release to the first instruction execution of application image ?
6 回复数
265 次查看
ZhangJennie
Hi @limingzhou
All LPC55S3x security documents are posted on the device homepage
https://www.nxp.com/products/LPC553x#myDocument
Select "Secure" option, you will see the list
LPC55S36 has PSA level 3 certificate, see declaration here
https://products.psacertified.org/products/lpc55s36
Regarding to your Q2 of boot time, The LPC55S3x supports booting from internal flash, external flash, or ISP mode, depending on configuration. the boot time information is not documented in any existing files. So I suggest you creating a private ticket to request it. Please address your project information and why this information is necessary to you in your ticket. Our support team will get back to you for it.
Jun Zhang
257 次查看
limingzhou
Hi Jun,
Thanks for your quick response.
Regarding boot time,  we use booting from internal flash.
And I raised a case ticket some days ago, like below link.
Not get feedback yet.
case number  00733967
https://support.nxp.com/s/case/500Tg00000PBQ5eIAH/security-features-of-lpc55s36jhi48
259 次查看
limingzhou
Hi Jun,
Again,
 I tried to open the documentation section on the device homepage.
 By selecting "Secure" option,  however there us nothing document available.
 Seems no access rights.
 I logged in using my NXP account,
232 次查看
ZhangJennie
@limingzhou
Please follow the link on your screenshot to request the access right. You will see the security documents after getting approved.
Jun Zhang
220 次查看
limingzhou
Hi Jun,
As you suggest creating a private ticket,
is it ok like below case I just created ?
214 次查看
ZhangJennie
Yes,  I tracked internally it was successfully created. We have another team for this topic will support it.
