Missing "CLOCK_DisableClock(kCLOCK_Iocon);" in pin_mux.c
1,331 次查看
1234567890
I miss the function
at the end of pin_mux.c generated with the Pins tool (actual SDK for LPC845-BRK).
Clocks for Iocon, Swm and Gpio0 are enabled at the beginning.
At the end Gpio0 remains enabled (of course) and Swm ist disabled. Even UM says:
标签 (1)
1 回复
1,310 次查看
diego_charles
Hi @1234567890
Thank you for your pointers!  I will pass your comments.
At this moment,  if reducing power consumption is required , since the generated code  by config tools can not be edited manually,  one should call the CLOCK_DisableClock(kCLOCK_Iocon) in other place.
Diego.
