MCUXpresso IDE vs Config
815 次查看
JK_265
I have to say I am a little confused about the MCUXpresso IDE and Config tools.
The IDE will not let me select IAR as the toolchain, so the auto-generated code contains the 'portable' code for GCC.  I manually have to copy a few .C modules and a .ICF file from an IAR-specific example project.
On the other hand, the Config tool allows me to configure the toolchain to IAR, but does not allow SDK management activities.  So the auto-generated code from the Config tool does not include any components/drivers, etc...  Again, this would result in me manually copying files into my project.
Am I confused or is it not currently possible to auto-generate everything?  If not, are there plans to remedy this?
Thanks!
799 次查看
