LwIP Will Not Compile SDK 2.8.2 / MCUXpresso 11.2
LPChicago
SDK 2.8.2
MCUXpresso IDE v11.2.0 [Build 4120]
New Project, added SDK and the LwIP Middleware.  Project will not compile because of missing references:
../lwip/port/enet_ethernetif.c:76:5: error: unknown type name 'phy_config_t'; did you mean 'pll_config_t'?
76 | phy_config_t phyConfig;
Am I missing something to get this to build?
ZhangJennie
Hi LPChicago
Unfortunately the SDK doesn't support DP83848I PHY, user needs to develop it by self.
Have a nice day,
Jun Zhang
LPChicago
Thanks, Jun.
This is a custom board using the dp83848i PHY from TI.  Since this is a pretty common PHY is there a resource where I can get an implementation of the PHY drivers?
LPChicago
Thank you, Jun.
This is a custom board.  The Board Components tab is empty in my SDK.  Will I need to find a phy layer implementation for the part or will I have to write one myself?
ZhangJennie
Please let me know your specific part number? I will test it on my side.
Hi LPChicago
BTW, I can't  download your png file.
Jun Zhang
LPChicago
Thank you, Jun.
Here's my chip:
Chip: LPC54606J512
Core: core0_LPC54606J512
Package: LPC54606J512BD208
ZhangJennie
The error means you didn't add phy files to your project, please add them from SDK component. for example:
Best Regards
Jun Zhang
LPChicago
Thank you, Jun.
This is a custom board using a DP83848I PHY.  Since this is a pretty common PHY is there a driver for it that I can use with the SDK 2.8.2 stack?  I notice this PHY use to be supported in past libraries.
ZhangJennie
Hi LPChicago
Have a nice day,
Jun Zhang
