Looking for a copy of Philips LPC2000 Flash utility and a little info :)
TAM
Hi folks, I am looking for a copy of Philips LPC2000 Flash utility, so that I may program an LPC2142. I repair amplifiers, and have a stack of em' with damaged LPC chips. What I need to do is connect to a functional amp, download the program, and then connect to a unit that I have replaced the LPC on and load the program.  Is this possible? It is a 4pin header connected to the amp. I'll need a serial interface board (some advice on an affordable one would be appreciated). Thank you, thank you, thank you!
xiangjun_rong
I suppose that the Flashmagic tools supports the LPC2000 family, pls go to the website and download Flashmagic tools.
https://www.flashmagictool.com
https://www.flashmagictool.com/supporteddevices.html
Hope it can help you
XiangJun Rong
