[LPCOpen] Bug in lcd_17xx_40xx.c
864件の閲覧回数
lpcware
Content originally posted in LPCWare by pgr on Mon Nov 10 01:37:59 MST 2014
Hy all,
I just found a bug in LPCOpen in the file lcd_17xx_40xx.c, function Chip_LCD_Init().
The clock divider is not computed the right way. The LCD controller use cclk as clock source and not pclk. So the code should be:
pcd = (Chip_Clock_GetSystemClockRate() / LCD_ConfigStruct->CLK) - 1;
instead of
pcd = (Chip_Clock_GetPeripheralClockRate() / LCD_ConfigStruct->CLK) - 1;
PGR
0 返答(返信)
