LPC844 低功耗
LPC844 低功耗
kentsun
jeremyzhou
Hi kent sun
I'd like to suggest you use the PIO0_10 and PIO0_11as the I2C_SCL, I2C_SDA, respectively.
The PIO0_10 and PIO0_11 can be programmed to support a true open-drain, in other word, removing the external resistors are available.
Please give a try.
TIC
kentsun
去掉上拉电阻后,IIC不能正常工作。
kent
sun
136-1184-5798
 发件人: jeremyzhou发送时间: 2019-03-05 10:16收件人: kent sun主题: Re: - Re: LPC844   低功耗
NXP Community
Re: LPC844   低功耗
reply from jeremyzhou in LPC Microcontrollers - View the full discussion
Hi kent sunThank you for your interest in NXP Semiconductor products and for the opportunity to serve you.
Please give a try.
TIC
jeremyzhou
Hi kent sun,
感谢回复!
对的,确实需要上拉电阻,我原来的回复有出错,抱歉。
在LPC844进入低功耗模式后,在上拉电阻上的电量损耗,无法被完全去除,因为这个“回路”始终存在,但可以尝试适当增大上拉电阻来降低损耗。
TIC
