LPC822 measuring wrong value
975件の閲覧回数
adamkulpa
Hi!
I'm working with NXP LPC822M101JDH20J and I'm trying to read adc values from PIO_23/ADC_3 pin with build in ROM ADC API. The Code attached below.
Constant signal is connected to PIO_23 pin and his value is 2,29 V. Reference voltage is 3,0 V on pin VREFP.
ADC hardware is configured as follow:
- 12 bit resolution
- clock: ADC_MAX_SAMPLE_RATE (with system clock: 30 MHz, sample: 1,2 M sample/s)
- sequential mode on channel 3
- polling mode
I'm able to perform analog to digital conversion, except that values are wrong when I do continuous code execution (in loop).
     while (1)
       putLineUART("MEAS: start\n");
       getValuesADC();
       putLineUART("MEAS value: ");
       itoa((int)adc_buffer[ADC_CHANNEL], buffer, 10);
       putLineUART(buffer);
       putLineUART("\n");
       putLineUART("MEAS: end\n");
static void getValuesADC()
  volatile uint32_t regVal;
  ADC_PARAM_T adc_param;
  ErrorCode_t err_code;
  /* ADC Param for SEQA read */
  adc_param.buffer = (uint32_t*) adc_buffer;
  adc_param.driver_mode = DRIVER_MODE_POLLING; /* Polling Mode */
  adc_param.seqa_hwtrig = 0;
  adc_param.adc_cfg = &adc_cfg; /* ADC Config */
  adc_param.comp_flags = 0;
  err_code = LPC_OK;
  err_code |= LPC_ADCD_API->adc_seqa_read(adc_handle, &adc_param);
  if (err_code != LPC_OK)
    errorADC();
Result value is 3839 in decimal but due conversion, i should got (2,29/3,0) x 4095 = 3125 result in decimal.
The difference is 714 points, in voltage (714/4095)*3,0V = 0.52 V. Error is too much.
While in debug step mode i got proper result value 3135 which is close to calculated.
I tried to add delay between readings, but I observed no effect - still wrong values.
Does strange behavior of the ADC can be evoked by wrong configuraction or usage?
How ROM API works in polling mode eg. function adc_seqa_read() is it blocking ?
Can someone explain me why in continuous execuction i got higher values?
PS.
I also tried code from the example with LPC OPEN, but also ocure strange behavior of reading.
Adam Kulpa
2 返答(返信)
779件の閲覧回数
adamkulpa
I found that my power line was corrupted and the mcu had 2,55 V on Vdd pin. Strange ADC reading was caused by Vdd < VREFP. I manage to power mcu properly with 3,3 V, and after that everything works normally. Conclusion is: always check the adc working conditions Vdd >= VREFP.
Thank you for quick response.
Adam Kulpa
779件の閲覧回数
jeremyzhou
Hi Adam Kulpa ,
Thank you for your interest in NXP Semiconductor products and
the opportunity to serve you.
I was wondering if you can share a compile-able demo which can replicate the phenomenon, and also sharing the sch of own board will be better.
TIC
