LPC55xx GPIO
LPC55xx GPIO
1,017件の閲覧回数
ianbenton
Senior Contributor I
Are the GPIO inputs 5V tolerant?
If not, are there protection diodes from input to Vdd and Vss, so that it would be possible to connect a 5V input simply by using a current limiting resistor and allowing the upper protection diode to conduct (as is normally done in logic gates)?
4 返答(返信)
1,005件の閲覧回数
gusarambula
Hello ianbenton,
The LPC55XX GPIOs are not 5V tolerant. Only the VBUS pin is 5V tolerant. For more details please refer to the LPC55XX Datasheet.
My apologies for the inconvenience.
Gustavo
1,002件の閲覧回数
ianbenton
Not inconvenient if I find out now.
Only inconvenient if I find out AFTER I've made my pcb.
I don't see any spec for the maximum current through the protection diode.
Also, the spec implies that the maximum voltage on a GPIO pin is 3.6V regardless of the value of Vdd. i.e  the pin could be taken 1.8V above Vdd if Vdd were 1.8V.
Is this correct?
1,000件の閲覧回数
ianbenton
Found the maximum voltage spec elsewhere in the datasheet, but not the maximum current through the protection diodes.
990件の閲覧回数
gusarambula
Hello ianbenton,
The maximum current trough the protection diodes is not characterized in the datasheet. There are some pin static characteristics including input current which would be the recommended limit.
Gustavo
