LPC55S69 : flash prefetch bit is dropped after PowerDown
859 次查看
EugeneHiihtaja
Senior Contributor I
Hello !
I'm setting Flash prefetch bit for accelerate performance.
Testing show that it set to 0 while PowerDown mode.
Is this true ?
Before :
+SYSCON->FMCCR 0xB03A  -> 150Mhz, prefetch ON
After:
-SYSCON->FMCCR 0x101A -> 12Mhz, prefetch OFF
Setting on FMCCCR in BOARD_BootClockFRO12M();
done in correct way.
Eugene
817 次查看
Sabina_Bruce
Hi Eugene,
Could you please confirm the revision of your LPC55S69?
Can you please clarify what testing is done?
Sabina
817 次查看
EugeneHiihtaja
Hi sabinabruce‌ !
Everything is latest. Board revision A2.
When prefecth is enabled it is +25% gain in performance of software cryptography tests.
So prefecth is working if it enabled.
Eugene
